Méthodologie de conception de textures pour les interfaces tactiles à frottement programmable - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The design of textures for so-called variable friction technologies requires multiple perspectives, which this paper aims to outline and discuss. We first propose a definition of texture and describe the current state of knowledge on their perception. After presenting two technologies for variable friction and comparing them to other tactile interfaces, we describe several particular uses for these devices. We then discuss psychophysical methods for signal perception evaluation and finally discuss methodologies for creating multidimensional tactile content.
potier12.pdf (131.35 Ko) Télécharger le fichier
hal-00719789 , version 1 (22-06-2018)
Ludovic Potier, Thomas Pietrzak, Géry Casiez, Nicolas Roussel. Méthodologie de conception de textures pour les interfaces tactiles à frottement programmable. Ergo'IHM 2012 - Proceedings of the AFIHM Conférence Francophone sur l’interaction Homme-Machine, Oct 2012, Biarritz, France. pp.132-139, ⟨10.1145/2652574.2653420⟩. ⟨hal-00719789⟩
372 Consultations
198 Téléchargements
