A Language for Multi-threaded Active Objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
The active object programming model is particularly adapted to easily program distributed objects: it separates objects into several activities, each manipulated by a single thread, preventing data races. However, this programming model has its limitations in terms of expressiveness -- risk of deadlocks -- and of efficiency on multicore machines. To overcome these limitations, this paper presents an extension of the active object model, called multi-active objects, that allows each activity to be multithreaded. The new model is implemented as a Java library and relies on method annotations to decide which requests can be run in parallel. It provides implicit parallelism, sparing the programmer from low-level concurrency mechanisms. We define the operational semantics of the multi-active objects and study the basic properties of this model. The benefits of our proposal are highlighted using two different applications: the NAS Parallel Benchmarks and a peer-to-peer overlay. This report presents the multi-active object programming model, its implementation in Java, its formal semantics and properties, and some experiments showing its efficiency.
RR-8021.pdf (757.52 Ko) Télécharger le fichier
hal-00720012 , version 1 (23-07-2012)
hal-00720012 , version 2 (15-02-2013)
  • HAL Id : hal-00720012 , version 1
Ludovic Henrio, Fabrice Huet, Zsolt István. A Language for Multi-threaded Active Objects. [Research Report] RR-8021, 2012. ⟨hal-00720012v1⟩
Collections
INRIA-RRRT
289 Consultations
256 Téléchargements
