A self-organization framework for wireless ad hoc networks as small worlds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Vehicular Technology Année : 2012
Motivated by the benefits of small-world networks, we propose a self-organization framework for wireless ad hoc networks. We investigate the use of directional beamforming for creating long-range short cuts between nodes. Using simulation results for randomized beamforming as a guideline, we identify crucial design issues for algorithm design. Our results show that, while significant path length reduction is achievable, this is accompanied by the problem of asymmetric paths between nodes. Subsequently, we propose a distributed algorithm for small-world creation that achieves path length reduction while maintaining connectivity. We define a new centrality measure that estimates the structural importance of nodes based on traffic flow in the network, which is used to identify the set of nodes that beamform. We show using simulations that this leads to a significant reduction in path length while maintaining connectivity.
1203.1185v1.pdf (534 Ko) Télécharger le fichier
hal-00724347 , version 1 (20-08-2012)
Abhik Banerjee, Rachit Agarwal, Vincent Gauthier, Yeo Chai Kiat, Hossam Afifi, et al.. A self-organization framework for wireless ad hoc networks as small worlds. IEEE Transactions on Vehicular Technology, 2012, 61 (6), pp.2659-2673. ⟨10.1109/TVT.2012.2197768⟩. ⟨hal-00724347⟩
137 Consultations
358 Téléchargements
