Fractional order differentiation by integration with Jacobi polynomials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The differentiation by integration method with Jacobi polynomials was originally introduced by Mboup, Join and Fliess. This paper generalizes this method from the integer order to the fractional order for estimating the fractional order derivatives of noisy signals. The proposed fractional order differentiator is deduced from the Jacobi orthogonal polynomial filter and the Riemann-Liouville fractional order derivative definition. Exact and simple formula for this differentiator is given where an integral formula involving Jacobi polynomials and the noisy signal is used without complex mathematical deduction. Hence, it can be used both for continuous-time and discrete-time models. The comparison between our differentiator and the recently introduced digital fractional order Savitzky-Golay differentiator is given in numerical simulations so as to show its accuracy and robustness with respect to corrupting noises.
Jacobi_fractional_order_differentiator_V1.pdf (181.03 Ko) Télécharger le fichier
hal-00728406 , version 1 (05-09-2012)
Da-Yan Liu, Olivier Gibaru, Wilfrid Perruquetti, Taous-Meriem Laleg-Kirati. Fractional order differentiation by integration with Jacobi polynomials. 51st IEEE Conference on Decision and Control, Dec 2012, Hawaii, United States. ⟨hal-00728406⟩
455 Consultations
396 Téléchargements
