State-Dependent Sampling for Linear Time Invariant Systems: A Discrete Time Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work concerns the adaptation of sampling times for Linear Time Invariant (LTI) systems controlled by state feedback. Complementary to various works that guarantee stabilization independently of changes in the sampling rate, here we provide conditions to design stabilizing sequences of sampling instants. In order to reduce the number of these sampling instants, a dynamic scheduling algorithmoptimizes, over a given sampling horizon, a sampling sequence depending on the system state value. Our proofs are inspired on switched system techniques combining Lyapunov functions and LMI optimization. To show the applicability of the technique, theoretical study is illustrated by an implementation in Matlab/ TRUE TIME.
MED.pdf (305.4 Ko) Télécharger le fichier
hal-00733212 , version 1 (18-09-2012)
  • HAL Id : hal-00733212 , version 1
Sonia Maalej, Christophe Fiter, Laurentiu Hetel, Jean-Pierre Richard. State-Dependent Sampling for Linear Time Invariant Systems: A Discrete Time Analysis. 20th Mediterranean Conference on Control & Automation (MED), Jul 2012, Barcelone, Spain. pp.1129 - 1134. ⟨hal-00733212⟩
173 Consultations
160 Téléchargements
