A 140 mV Self-Starting 10 mW DC/DC Converter for Powering Low-Power Electronic Devices from Low-Voltage Microbial Fuel Cells - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Low Power Electronics Année : 2012
Nicolas Degrenne
  • Fonction : Auteur
  • PersonId : 873059
François Buret
Christian Vollaire
Connectez-vous pour contacter l'auteur
Florent Morel
This paper presents an original self-starting DC/DC converter for low-power and low-voltage applications such as energy harvesting from microbial fuel cells to supply low-power electronic devices. Design is performed according to specifications issued from the stringent characteristics of microbial fuel cells. The harvested power reaches 10 mW under 0.3 V input voltage for the ten 1.3-liter experimental microbial fuel cells connected in parallel. The converter is adapted from a boost topology. It includes a self-oscillating sub-circuit for autonomous operation and a simple analog input-voltage control to harvest maximum energy from the source. The paper presents experimental results from a discrete and low-cost prototype. A global efficiency of more than 73% is achieved for 0.3 V input-voltage and under realistic harvesting conditions for the MFCs and the converter prototype.
Fichier non déposé
hal-00733976 , version 1 (20-09-2012)
Nicolas Degrenne, Bruno Allard, François Buret, Salah-Eddine Adami, Denis Labrousse, et al.. A 140 mV Self-Starting 10 mW DC/DC Converter for Powering Low-Power Electronic Devices from Low-Voltage Microbial Fuel Cells. Journal of Low Power Electronics, 2012, 8 (4), pp.485-497. ⟨10.1166/jolpe.2012.1209⟩. ⟨hal-00733976⟩
440 Consultations
0 Téléchargements
