A visual perception account of programming languages : finding the natural science in the art - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
There is no agreed set of grounded principles on which to rely to analyze and discuss code representations. I propose a combination of Semiotic of Graphics and ScanVis. I discovered that this unifying framework brings together many aspects of visual layout and appearance of programming languages. We describe how the framework applies to programming languages, which is not obvious and has never been done before. We show how to use the framework to compare representation of code by relying on sound arguments. Finally, we use the framework to devise design principles to help generate new representations. Relying on such a framework can help researchers and designers invent better languages with respect to this concern. This work also suggests that the gap between textual and graphical languages is narrow, and that true visual languages should rely on the capability of the human visual system.
langViz-popl-submitted.pdf (2.24 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00737414 , version 1 (01-04-2013)
  • HAL Id : hal-00737414 , version 1
Stéphane Conversy. A visual perception account of programming languages : finding the natural science in the art. 2012. ⟨hal-00737414⟩
1066 Consultations
584 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
