Rationally connected manifolds and semipositivity of the Ricci curvature - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Frédéric Campana
  • Fonction : Auteur
  • PersonId : 931065
Jean-Pierre Demailly
Thomas Peternell
  • Fonction : Auteur
  • PersonId : 931020
This work establishes a structure theorem for compact Kähler manifolds with semipositive anticanonical bundle. Up to finite étale cover, it is proved that such manifolds split holomorphically and isometrically as a product of Ricci flat varieties and of rationally connected manifolds. The proof is based on a characterization of rationally connected manifolds through the non existence of certain twisted contravariant tensor products of the tangent bundle, along with a generalized holonomy principle for pseudoeffective line bundles. A crucial ingredient for this is the characterization of uniruledness by the property that the anticanonical bundle is not pseudoeffective.
cdp2_cor.pdf (196.55 Ko) Télécharger le fichier
hal-00739178 , version 1 (07-10-2012)
hal-00739178 , version 2 (21-01-2014)
hal-00739178 , version 3 (04-02-2018)
Frédéric Campana, Jean-Pierre Demailly, Thomas Peternell. Rationally connected manifolds and semipositivity of the Ricci curvature. Recent advances in algebraic geometry, 2013, Ann Harbor, United States. pp.71-91. ⟨hal-00739178v3⟩
361 Consultations
341 Téléchargements
