Vacuum casting, a new answer to manufacture biomicrosystems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Engineering Manufacture Année : 2005
In this work, the vacuum-casting process is pushed to its dimensional limits thanks to microfabricated original parts. The successful replication of those parts with a slightly adapted vacuum-casting process demonstrates that this technique is suitable for biomicrosystem manufacturing and development.
hal-00739222 , version 1 (06-10-2012)
Matthieu Denoual, Pascal Mognol, Bruno Le Pioufle. Vacuum casting, a new answer to manufacture biomicrosystems. Journal of Engineering Manufacture, 2005, 219 (9), pp.697-502. ⟨10.1243/095440505X32571⟩. ⟨hal-00739222⟩
126 Consultations
0 Téléchargements
