Parallel transport in a tokamak scrape-off layer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sudden transient events - such as edge-localized modes (ELMs) - routinely occur in the tokamak edge during H-mode confinement. ELMs are plasma relaxations that cause a sudden drop in density and temperature of the pedestal plasma, leading to a significant loss of the stored plasma energy. Once the ELM-driven plasma pulse has crossed the magnetic separatrix, it travels mainly parallel to the magnetic field lines and ends up hitting the divertor plate, after a delay typically of the order of a few hundred microseconds. In the present paper, the fully nonlinear parallel dynamics in the scrape-off layer is solved by means of a self-consistent kinetic model (Vlasov-Poisson equations). The Vlasov equation is integrated numerically using an Eulerian method, which guarantees a high resolution in velocity space, even in regions of low plasma density such as the sheaths. The model is applied to the study of parallel transport during edge-localized modes (ELMs), with particular emphasis on the energy fluxes on the divertor plates. The numerical results are compared to analytical estimates based on a free-streaming model, and to numerical simulations performed using two different approaches: a particle-in-cell code and a one-dimensional fluid code. An interesting feature is the observation of an early electron energy flux, due to suprathermal electrons escaping the ions' attraction.
P4_063.pdf (235.96 Ko) Télécharger le fichier
hal-00739259 , version 1 (07-10-2012)
  • HAL Id : hal-00739259 , version 1
Giovanni Manfredi, Sever Adrian Hirstoaga, Stéphane Devaux, Eva Havlickova, David Tskhakaya. Parallel transport in a tokamak scrape-off layer. 38th EPS Conference on Plasma Physics, Jun 2011, Strasbourg, France. pp.P4.063. ⟨hal-00739259⟩
375 Consultations
148 Téléchargements
