Multi-atlas labeling with population-specific template and non-local patch-based label fusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a new method combining a population-specific nonlinear template atlas approach with non-local patch-based structure segmentation for whole brain segmentation into individual structures. This way, we benefit from the efficient intensity-driven segmentation of the non-local means framework and from the global shape constraints imposed by the nonlinear template matching.
vfonov-multiatlas-challenge-v2.pdf (4.51 Mo) Télécharger le fichier
hal-00739285 , version 1 (07-10-2012)
  • HAL Id : hal-00739285 , version 1
Vladimir Fonov, Pierrick Coupé, Simon F. Eskildsen, Jose V. Manjon, Louis Collins. Multi-atlas labeling with population-specific template and non-local patch-based label fusion. MICCAI 2012 Workshop on Multi-Atlas Labeling, Oct 2012, Nice, France. pp.63-66. ⟨hal-00739285⟩
Collections
CNRS
218 Consultations
276 Téléchargements
