Off-line Test Selection with Test Purposes for Non-Deterministic Timed Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Logical Methods in Computer Science Année : 2012
This article proposes novel off -line test generation techniques from non-deterministic timed automata with inputs and outputs (TAIOs) in the formal framework of the tioco conformance theory. In this context, a first problem is the determinization of TAIOs, which is necessary to foresee next enabled actions after an observable trace, but is in general impossible because not all timed automata are determinizable. This problem is solved thanks to an approximate determinization using a game approach. The algorithm performs an io-abstraction which preserves the tioco conformance relation and thus guarantees the soundness of generated test cases. A second problem is the selection of test cases from a TAIO speci cation. The selection here relies on a precise description of timed behaviors to be tested which is carried out by expressive test purposes modeled by a generalization of TAIOs. Finally, an algorithm is described which generates test cases in the form of TAIOs equipped with verdicts, using a symbolic co-reachability analysis guided by the test purpose. Properties of test cases are then analyzed with respect to the precision of the approximate determinization: when determinization is exact, which is the case on known determinizable classes, in addition to soundness, properties characterizing the adequacy of test cases verdicts are also guaranteed.
1207.6267.pdf (556.33 Ko) Télécharger le fichier
hal-00744074 , version 1 (22-10-2012)
  • HAL Id : hal-00744074 , version 1
Nathalie Bertrand, Thierry Jéron, Amélie Stainer, Moez Krichen. Off-line Test Selection with Test Purposes for Non-Deterministic Timed Automata. Logical Methods in Computer Science, 2012, 8 (4:8), pp.1-33. ⟨hal-00744074⟩
107 Consultations
150 Téléchargements
