Managing advertising campaigns -- an approximate planning approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers of Computer Science Année : 2012
Sertan Girgin
  • Fonction : Auteur
  • PersonId : 844332
Jérémie Mary
Philippe Preux
Olivier Nicol
  • Fonction : Auteur
  • PersonId : 879461
We consider the problem of displaying commercial advertisements on web pages, in the "cost per click" model. The advertisement server has to learn the appeal of each type of visitor for the different advertisements in order to maximize the profit. Advertisements have constraints such as a certain number of clicks to draw, as well as a lifetime. This problem is thus inherently dynamic, and intimately combines combinatorial and statistical issues. To set the stage, it is also noteworthy that we deal with very rare events of interest, since the base probability of one click is in the order of 10−4. Different approaches may be thought of, ranging from computationally demanding ones (use of Markov decision processes, or stochastic programming) to very fast ones.We introduce NOSEED, an adaptive policy learning algorithm based on a combination of linear programming and multi-arm bandits. We also propose a way to evaluate the extent to which we have to handle the constraints (which is directly related to the computation cost). We investigate the performance of our system through simulations on a realistic model designed with an important commercial web actor.
FCS-11073.final.pdf (1.73 Mo) Télécharger le fichier
hal-00747722 , version 1 (08-11-2012)
Sertan Girgin, Jérémie Mary, Philippe Preux, Olivier Nicol. Managing advertising campaigns -- an approximate planning approach. Frontiers of Computer Science, 2012, 6 (2), pp.209-229. ⟨10.1007/s11704-012-2873-5⟩. ⟨hal-00747722⟩
291 Consultations
996 Téléchargements
