New interface
Journal articles
Identification of microwave filters by analytic and rational H2 approximation
Abstract : In this paper, an original approach to frequency identification is explained and demonstrated through an application in the domain of microwave filters. This approach splits into two stages: a stable and causal model of high degree is first computed from the data (completion stage); then, model reduction is performed to get a rational low order model. In the first stage the most is made of the data taking into account the expected behaviour of the filter. A reduced order model is then computed by rational H2 approximation. A new and efficient method has been developed, improved over the years and implemented to solve this problem. It heavily relies on the underlying Hilbert space structure and on a nice parametrization of the optimization set. This approach guarantees the stability of the MIMO approximant of prescribed McMillan degree.
Document type :
Journal articles
Complete list of metadata
Cited literature [38 references]  Display  Hide  Download
https://hal.inria.fr/hal-00753824
Contributor : Martine Olivi Connect in order to contact the contributor
Submitted on : Monday, November 19, 2012 - 4:38:51 PM
Last modification on : Tuesday, October 25, 2022 - 4:18:11 PM
Long-term archiving on: : Thursday, February 21, 2013 - 11:35:08 AM
File
AUTO_MOSfinal.pdf
Identifiers
Citation
Martine Olivi, Fabien Seyfert, Jean-Paul Marmorat. Identification of microwave filters by analytic and rational H2 approximation. Automatica, 2013, 49 (2), pp.317-325. ⟨10.1016/j.automatica.2012.10.005⟩. ⟨hal-00753824⟩
Share
Metrics
Record views
400
Files downloads
350
