Semantic Clustering using Bag-of-Bag-of-Features - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Computing distances between textual representation is at the heart of many Natural Language Processing tasks. The standard approaches initially developed for Information Retrieval are then used; most often they rely on a bag-of-words (or bag-of-feature) description with a TF-IDF (or variants) weighting, a vectorial representation and classical similarity functions like cosine. In this paper, we are interested in such a task, namely the semantic clustering of entities extracted from a text. We argue that for this kind of tasks, more suited representations and similarity measures can be used. In particular, we explore the use of alternative representation for entities called Bag-Of-Vectors (or Bag-of-Bags-of-Features). In this new model, each entity is not defined as a unique vector but as a set of vectors, in which each vector is built based on the contextual features of one occurrence of the entity. In order to use Bag-Of-Vectors for clustering, we introduce new versions of classical similarity functions such as Cosine, Jaccard and Scalar Products. Experimentally, we show that the Bag-Of-Vectors representation always improve the clustering results compared to classical Bag-Of-Features representations.
CORIA.pdf (283.02 Ko) Télécharger le fichier
hal-00753912 , version 1 (19-11-2012)
  • HAL Id : hal-00753912 , version 1
Ali-Reza Ebadat, Vincent Claveau, Pascale Sébillot. Semantic Clustering using Bag-of-Bag-of-Features. CORIA - COnférence en Recherche d'Information et Applications, Mar 2012, Bordeaux, France. pp.229-244. ⟨hal-00753912⟩
399 Consultations
343 Téléchargements
