CCNx for Contiki: implementation details - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2012
In this work we adapted the Content Centric Networking (CCN) approach which is a promising communication architecture based on named data to be employed in wireless sensor networks. We implemented and integrated a CCN communication stack into Contiki which is an operating system for resources-constrained embedded systems and wireless sensor networks. We evaluated our implementation using a synthetic monitoring application under varying network sizes through simulation and a real deployment on the SensLAB testbed.
RT-432.pdf (2.1 Mo) Télécharger le fichier
hal-00755482 , version 1 (22-11-2012)
  • HAL Id : hal-00755482 , version 1
Bilel Saadallah, Abdelkader Lahmadi, Olivier Festor. CCNx for Contiki: implementation details. [Technical Report] RT-0432, INRIA. 2012, pp.52. ⟨hal-00755482⟩
1889 Consultations
2151 Téléchargements
