How INRIA/IRISA identifies Geographic Location of a Video - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we describe our approaches and their results as part of the MediaEval 2012 Placing Task evaluation. We present two di erent tag-based techniques. Both rst preselect one or several geographic area of interest and then perform a deeper analysis inside the selected area(s) to return the coordinates more likely to be related with the input tags. In addition, we also implement a content-based method that uses aggregated local images descriptors (VLAD) to nd the video's visual nearest neighbors and infer its coordinates. In this work we do not use gazetteers or any other external information.
mediaeval2012_submission_17.pdf (282.44 Ko) Télécharger le fichier
hal-00757453 , version 1 (27-11-2012)
  • HAL Id : hal-00757453 , version 1
Michele Trevisiol, Jonathan Delhumeau, Hervé Jégou, Guillaume Gravier. How INRIA/IRISA identifies Geographic Location of a Video. Working Notes Proceedings of the MediaEval 2012 Workshop, 2012, Italy. ⟨hal-00757453⟩
446 Consultations
146 Téléchargements
