An Optimal Transport Approach to Robust Reconstruction and Simplification of 2D Shapes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2011
Fernando de Goes
  • Fonction : Auteur
  • PersonId : 873934
David Cohen-Steiner
Pierre Alliez
Mathieu Desbrun
We propose a robust 2D shape reconstruction and simplification algorithm which takes as input a defect-laden point set with noise and outliers. We introduce an optimal-transport driven approach where the input point set, considered as a sum of Dirac measures, is approximated by a simplicial complex considered as a sum of uniform measures on 0- and 1-simplices. A fine-to-coarse scheme is devised to construct the resulting simplicial complex through greedy decimation of a Delaunay triangulation of the input point set. Our method performs well on a variety of examples ranging from line drawings to grayscale images, with or without noise, features, and boundaries.
DCAD11.pdf (2.03 Mo) Télécharger le fichier
Format : Figure, Image
hal-00758019 , version 1 (27-05-2013)
  • HAL Id : hal-00758019 , version 1
Fernando de Goes, David Cohen-Steiner, Pierre Alliez, Mathieu Desbrun. An Optimal Transport Approach to Robust Reconstruction and Simplification of 2D Shapes. Computer Graphics Forum, 2011, Eurographics Symposium on Geometry Processing 2011, 30 (5), pp.1593-1602. ⟨hal-00758019⟩
268 Consultations
501 Téléchargements
