On the Use of Wavelets and Cepstrum Excitation for Pitch Determination in Real-Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the current paper, we propose a new pitch tracking technique based on a wavelet transform in the temporal domain. Our algorithm is designed to determine the pitch frequency of the speech signal using a simple voicing decision algorithm. The pitch period is extracted from the cepstrum excitation signal processed by a wavelet transform; then the pitch contour is refined by thresholding and correction algorithms without any post-processing. The results obtained show that the proposed algorithm provides very good pitch contours compared to those furnished by the Bagshaw database.
ID_173_Fadoua_BAHJA_ICMCS_2012.pdf (520.13 Ko) Télécharger le fichier
hal-00761819 , version 1 (10-12-2012)
  • HAL Id : hal-00761819 , version 1
Fadoua Bahja, El Hassan Ibn Elhaj, Joseph Di Martino. On the Use of Wavelets and Cepstrum Excitation for Pitch Determination in Real-Time. 3rd International Conference on Multimedia Computing and Systems - ICMCS'12, May 2012, Tangier, Morocco. ⟨hal-00761819⟩
149 Consultations
3130 Téléchargements
