On the estimation of sequestered parasite population in falciparum malaria patients
The aim of this paper is to give an estimation of total parasite burden of the patient and the rate of infection in a malaria's intra-host model by using control theory tools. More precisely, we use an auxiliary system called observer whose solutions tend exponentially to those of the original model. This observer uses only the available measurable data that are the values of peripheral infected erythrocytes and provides estimates of the sequestered ones that cannot be measured by clinical methods. Therefore this allows to estimate the total parasite burden within a malaria patient. Moreover the constructed observer does not use the generally unknown infection rate parameter $\beta$. We also derive a simple method to estimate this parameter $\beta$. We apply this estimation method using real data that have been collected when malaria was used as therapy for neurosyphilis by the US Public Health Service.
L'objectif de ce papier est de donner une estimation de la charge parasitaire totale d'un patient á partir de sa charge parasitaire périphérique. On donne aussi une méthode d'estimation du taux d'infection $\beta$ dans un modéle intra-hôte du paludisme en utilisant les outils de la théorie du contrôle.
