New interface
Journal articles
Optimal Boundary Conditions for ORCA-2 Model
Eugene Kazantsev 1, *
* Corresponding author
1 MOISE - Modelling, Observations, Identification for Environmental Sciences
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
Abstract : A 4D-Var data assimilation technique is applied to a ORCA-2 configuration of the NEMO in order to identify the optimal parametrization of the boundary conditions on the lateral boundaries as well as on the bottom and on the surface of the ocean. The influence of the boundary conditions on the solution is analyzed as in the assimilation window and beyond the window. It is shown that optimal conditions for vertical operators allows to get stronger and finer jet streams (Gulf Stream, Kuroshio) in the solution. Analyzing the reasons of the jets reinforcement, we see that the major impact of the data assimilation is made on the parametrization of the bottom boundary conditions for lateral velocities u and v. Automatic generation of the tangent and adjoint codes is also discussed. Tapenade software is shown to be able to produce the adjoint code that can be used after a memory usage optimization.
Complete list of metadata
Cited literature [36 references]  Display  Hide  Download
https://hal.inria.fr/hal-00764570
Contributor : Eugene Kazantsev Connect in order to contact the contributor
Submitted on : Thursday, December 13, 2012 - 10:57:05 AM
Last modification on : Thursday, January 20, 2022 - 5:28:11 PM
Long-term archiving on: : Thursday, March 14, 2013 - 3:46:55 AM
orca.pdf
Identifiers
Collections
Citation
Eugene Kazantsev. Optimal Boundary Conditions for ORCA-2 Model. Ocean Dynamics, 2013, 63 (8), pp.943-959. ⟨10.1007/s10236-013-0639-8⟩. ⟨hal-00764570⟩
Share
Metrics
Record views
140
Files downloads
241
