Compressed sensing for acoustic response reconstruction: Interpolation of the early part - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The goal of this paper is to interpolate Room Impulse Responses (RIRs) within a whole volume, from a few measurements. We here focus on the early reflections, that have the key property of being sparse in the time domain: this can be exploited in a framework of model-based Compressed Sensing. Starting from a set of RIRs randomly sampled in space by a 3D microphone array, we use a modified Matching Pursuit algorithm to estimate the position of a small set of virtual sources. Then, the reconstruction of the RIRs at interpolated positions is performed using a projection onto a basis of monopoles. This approach is validated both by numerical and experimental measurements using a 120-microphone 3D array.
Fichier non déposé
hal-00766979 , version 1 (19-12-2012)
R. Mignot, L. Daudet, F. Ollivier. Compressed sensing for acoustic response reconstruction: Interpolation of the early part. Applications of Signal Processing to Audio and Acoustics (WASPAA), 2011 IEEE Workshop on, 2011, New Paltz, NY, United States. pp.225 -228, ⟨10.1109/ASPAA.2011.6082298⟩. ⟨hal-00766979⟩
111 Consultations
0 Téléchargements
