On the Feasibility of Measuring the Internet Through Smartphone-based Crowdsourcing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The large base of Internet-enabled smartphones provides an excellent opportunity for a fine-grained observation of the structure of the Internet and a quantitative evaluation of its characteristics. Smartphones can operate as active mobile monitors and, coordinated by a central entity, they can probe the network on a local scale. Then the results produced by a large number of participants can be merged to obtain a detailed graph of the Internet. Besides the design of the measurement framework, this paper describes the implementation and validation of a traceroute-like tool that is compatible with the Android platform. This confirms that smartphone-based crowdsourcing of network properties can be a viable strategy.
p318-faggiani.pdf (287.64 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-00767064 , version 1 (19-12-2012)
  • HAL Id : hal-00767064 , version 1
Adriano Faggiani, Enrico Gregori, Luciano Lenzini, Simone Mainardi, Alessio Vecchio. On the Feasibility of Measuring the Internet Through Smartphone-based Crowdsourcing. WiOpt'12: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2012, Paderborn, Germany. pp.318-323. ⟨hal-00767064⟩
Collections
WIOPT2012
87 Consultations
276 Téléchargements
