New interface
Journal articles
A posteriori error estimation for the heterogeneous Maxwell equations on isotropic and anisotropic meshes
Abstract : We consider residual-based a posteriori error estimators for the heterogeneous Maxwell equations using isotropic as well as anisotropic meshes. The continuous problem is approximated by using conforming approximated spaces with minimal assumptions. Lower and upper bounds are obtained under standard assumptions on the meshes. The lower bound holds unconditionally, while the upper bound depends on alignment properties of the meshes with respect to the solution. In particular for isotropic meshes the upper bound also holds unconditionally. A numerical test is presented which confirms our theoretical results.
Complete list of metadata
https://hal.inria.fr/hal-00768715
Contributor : Emmanuel Creusé Connect in order to contact the contributor
Submitted on : Sunday, December 23, 2012 - 10:02:23 AM
Last modification on : Tuesday, November 22, 2022 - 2:26:15 PM
Links full text
Identifiers
Citation
Serge Nicaise, Emmanuel Creusé. A posteriori error estimation for the heterogeneous Maxwell equations on isotropic and anisotropic meshes. Calcolo, 2003, 40, pp.249-271. ⟨10.1007/s10092-003-0077-y⟩. ⟨hal-00768715⟩
Share
Metrics
Record views
99
