Variability of <em>f</em>CO<sub>2</sub> in the Eastern Tropical Atlantic from a moored buoy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Geophysical Research Année : 2008
Variability of fCO2 in the Eastern Tropical Atlantic from a moored buoy
A fCO2 sensor, based on a colorimetric method used for the CARIOCA buoys, has been installed on a Pilot Research Moored Array in the Tropical Atlantic (PIRATA) mooring at 6°S, 10°W, in the gulf of Guinea, in June 2006 during the EGEE 3 cruise. Hourly fCO2 data recorded from June to December 2006 are presented. An alkalinity-salinity relationship has been determined using data from different cruises, which allows the calculation of dissolved inorganic carbon. Although the tropical Atlantic is an important source of CO2, an unexpected area of low CO2 concentrations is observed in the South Equatorial Counter Current with fCO2 values close to equilibrium conditions or even slightly undersaturated with respect to the atmospheric fCO2 value of 367.7 μatm measured during the cruise. At the end of June, an increase of seawater fCO2 to 400 μatm is consistent with the beginning of the upwelling season occurring from July to September. Although the mooring is not located within the upwelling area, the spreading of the cold tongue explains the large CO2 outgassing. The monthly CO2 flux ranges from 1.19 mmol m-2 d-1 in June to a maximum of 8.37 mmol m-2 d-1 in October, when high fCO2 values above 420 μatm are maintained by the warming of surface water. Most of the fCO2 distribution can be explained by physical processes and a strong relationship between fCO2 and SST is determined for the upwelling season. From mid-September, diurnal cycles can be detected. Using a dissolved inorganic carbon budget, periods where net community production or diurnal warming and cooling dominates are observed.
2007JC004146.pdf (1.91 Mo) Télécharger le fichier
hal-00770572 , version 1 (30-07-2021)
Copyright (Tous droits réservés)
Nathalie Lefèvre, Antoine Guillot, Laurence Beaumont, Théo Danguy. Variability of fCO2 in the Eastern Tropical Atlantic from a moored buoy. Journal of Geophysical Research, 2008, 113, pp.C01015. ⟨10.1029/2007JC004146⟩. ⟨hal-00770572⟩
133 Consultations
21 Téléchargements
