Hardware-Dependent Proofs of Numerical Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present an approach for proving behavioral properties of numerical programs by analyzing their compiled assembly code. We focus on the issues and traps that may arise on floating-point computa- tions. Direct analysis of the assembly code allows us to take into account architecture- or compiler-dependent features such as the possible use of extended precision registers. The approach is implemented on top of the generic Why platform for deductive verifi cation, which allows us to perform experiments where proofs are discharged by combining several back-end automatic provers.
main.pdf (389.93 Ko) Télécharger le fichier
hal-00772508 , version 1 (19-02-2013)
  • HAL Id : hal-00772508 , version 1
Thi Minh Tuyen Nguyen, Claude Marché. Hardware-Dependent Proofs of Numerical Programs. Certified Programs and Proofs, Dec 2011, Kenting, Taiwan. ⟨hal-00772508⟩
190 Consultations
297 Téléchargements
