A formally-verified alias analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper reports on the formalization and proof of soundness, using the Coq proof assistant, of an alias analysis: a static analysis that approximates the flow of pointer values. The alias analysis considered is of the points-to kind and is intraprocedural, flow-sensitive, field-sensitive, and untyped. Its soundness proof follows the general style of abstract interpretation. The analysis is designed to fit in the CompCert C verified compiler, supporting future aggressive optimizations over memory accesses.
alias-analysis.pdf (313.87 Ko) Télécharger le fichier
hal-00773109 , version 1 (11-01-2013)
Valentin Robert, Xavier Leroy. A formally-verified alias analysis. CPP 2012 - Second International Conference on Certified Programs and Proofs, Dec 2012, Kyoto, Japan. pp.11-26, ⟨10.1007/978-3-642-35308-6_5⟩. ⟨hal-00773109⟩
Collections
INRIA INRIA2 ANR
152 Consultations
222 Téléchargements
