From Neighbors to Global Neighbors in Collaborative Filtering: an Evolutionary Optimization Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The accuracy of recommendations of collaborative filtering bas\-ed recommender systems mainly depends on which users (the neighbors) are exploited to estimate a user's ratings. We propose a new approach of neighbor selection, which adopts a global point of view. This approach defines a unique set of possible neighbors, shared by all users, referred to as Global Neighbors ($GN$). We view the problem of defining $GN$ as a combinatorial optimization problem and propose to use an evolutionary algorithm to tackle this search. Our aim is to find a relatively small $GN$ as the size of the resulting model, as well as the complexity of the computation of recommendations highly depend on the size of $GN$. We present experiments and results on a standard benchmark data-set from the recommender system community that support our choice of the evolutionary approach and show that it leads to a high accuracy of recommendations and a high coverage, while dramatically reducing the size of the model (by 84\%). We also show that the evolutionary approach produces results able to generate accurate recommendations to unseen users, while easily allowing the insertion of new users in the system with little overhead.
Fichier non déposé
hal-00778495 , version 1 (20-01-2013)
Amine Boumaza, Armelle Brun. From Neighbors to Global Neighbors in Collaborative Filtering: an Evolutionary Optimization Approach. GECCO - Genetic and Evolutionary Computation Conference - 2012, Jul 2012, Philadelphia, United States. pp.345-352, ⟨10.1145/2330163.2330214⟩. ⟨hal-00778495⟩
111 Consultations
0 Téléchargements
