Risk mapping based on hidden Markov random field and variational approximations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The analysis of the geographic variation of disease and its representation on a map is an important tool in epidemiology which allows the detection of clusters of geographical areas characterized by homogeneity in the estimated relative risks and enables to understand the mechanisms which underlie the spread of the disease. Traditional approaches to disease mapping have some deficiencies and disadvantages in presenting the geographical distribution. The use, for example, of the crude Standardized Mortality Ratio (SMR) (The epidemiological measure under consideration) which is the ratio of observed cases $y$ over expected cases $e$, is becoming unpopular because of its instability, especially when rare diseases are investigated in an area with a small population. In such a case, both the observed and the expected value are low. As a result, an area with small population tends to present an extreme SMR. Alternatively, Poisson-based models that smooth the risk estimates are proposed to overcome theses deficiencies. The most popular approach in animal epidemiology is based on hierarchical Bayesian approaches designed for the estimation of risk at each geographical unit. The risk classification is performing manually, in a second time, by animal epidemiologists, with the difficult task of defining the risk ranges for each class. We propose an approach based on finite mixture models with spatial constraints, in which the risk classification is performed automatically. We assume that the counts follow a Poisson model and introduce a finite mixture model for the Poisson rates. The allocation to the mixture components is modeled through a hidden Markov Random Field (MRF) using a Potts presentation. Instead of using MCMC, which would be very time-consuming, we introduce the computational implementation of our model via the EM mean field algorithm. EM solution can highly depends on its starting position. In this work, we propose a way of initialization working well for most situations arising in practice. This initialization strategy consists in randomly drawing initial parameters in an appropriate space including all possible EM trajectories. The performance of our model is examined on synthetic data and real data set concerning the Bovin Spongiform Encephalopathy (BSE) in France.
Fichier non déposé
hal-00780575 , version 1 (24-01-2013)
  • HAL Id : hal-00780575 , version 1
David Abrial, Lamiae Azizi, Myriam Garrido, Florence Forbes. Risk mapping based on hidden Markov random field and variational approximations. 1st Conference on Spatial Statistics 2011, Mar 2011, Enschede, Netherlands. ⟨hal-00780575⟩
236 Consultations
0 Téléchargements
