Free Space Estimation for Autonomous Navigation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
One of the issues in autonomous navigation is the free space estimation. This paper presents an original framework and a method for the extraction of such an area by using a stereovision system. The v- disparity algorithm is extended to provide a reliable and precise road pro¯le on all types of roads. The free space is estimated by classifying the pixels of the disparity map. This classi¯cation is performed by using the road pro¯le and the u-disparity image. Each stage of the algorithm is presented and experimental results are shown.
ICVS2007-FreeSpaceEstimation.pdf (537.72 Ko) Télécharger le fichier
Origine Fichiers éditeurs autorisés sur une archive ouverte
hal-00780658 , version 1 (24-01-2013)
  • HAL Id : hal-00780658 , version 1
Nicolas Soquet, Mathias Perrollaz, Raphaël Labayrade, Didier Aubert. Free Space Estimation for Autonomous Navigation. 5th International Conference on Computer Vision Systems, 2007, Bielefeld, Germany. ⟨hal-00780658⟩
316 Consultations
1441 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
