Road Scene Analysis by Stereovision: a Robust and Quasi-Dense Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
A stereovision method is presented in this paper, to compute reliable and quasi-dense disparity maps of road scenes using in-vehicle cameras. It combines the advantages of the "v-disparity" approach and a quasi-dense matching algorithm. In this aim, road surface and vertical planes of the scene are first extracted using the sparse "v-disparity" approach. The knowledge of these global surfaces of the scene is then used to guide a quasi-dense matching algorithm and to propagate disparity information on horizontal edges. Both algorithms are presented and compared. Then, our approach is presented and examples of quasi-dense disparity maps are given. Finally, the efficiency of the method is illustrated by the accurate positioning of a bounding box around a vehicle in a bad contrasted video sequence.
ICARCV2006_SemiDense.pdf (510.09 Ko) Télécharger le fichier
hal-00780665 , version 1 (24-01-2013)
Nicolas Hautière, Raphaël Labayrade, Mathias Perrollaz, Didier Aubert. Road Scene Analysis by Stereovision: a Robust and Quasi-Dense Approach. International Conference on Control, Automation, Robotics and Vision (ICARCV), 2006, Singapour, Singapore. ⟨10.1109/ICARCV.2006.345163⟩. ⟨hal-00780665⟩
398 Consultations
538 Téléchargements
