OS for the IoT - Goals, Challenges, and Solutions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Internet of Things embodies a wide spectrum of machines ranging from sensors powered by 8-bit microcontrollers to devices powered by processors roughly equivalent to those found in entry-level smartphones. Neither traditional operating systems (OS) currently running on Internet hosts, nor typical OS for sensor networks are capable to fulfill all at once the diverse requirements of such a wide range of devices. Hence, in order to avoid redundant developments and maintenance costs of IoT products, a novel, unifying type of OS is needed. The following analyzes requirements such an OS should fulfill and introduces RIOT, an OS satisfying these demands.
2013-os4iot-final.pdf (215.08 Ko) Télécharger le fichier
hal-00781769 , version 1 (28-01-2013)
  • HAL Id : hal-00781769 , version 1
Emmanuel Baccelli, Oliver Hahm, Mesut Günes, Matthias Wählisch, Thomas C. Schmidt. OS for the IoT - Goals, Challenges, and Solutions. Workshop Interdisciplinaire sur la Sécurité Globale (WISG2013), Jan 2013, Troyes, France. ⟨hal-00781769⟩
Collections
INRIA INRIA2
709 Consultations
1991 Téléchargements
