Uniqueness of the fixed point of nonexpansive semidifferentiable maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transactions of the American Mathematical Society Année : 2016
We consider semidifferentiable (possibly nonsmooth) maps, acting on a subset of a Banach space, that are nonexpansive either in the norm of the space or in the Hilbert's or Thompson's metric inherited from a convex cone. We show that the global uniqueness of the fixed point of the map, as well as the geometric convergence of every orbit to this fixed point, can be inferred from the semidifferential of the map at this point. In particular, we show that the geometric convergence rate of the orbits to the fixed point can be bounded in terms of Bonsall's non-linear spectral radius of the semidifferential. We derive similar results concerning the uniqueness of the eigenline and the geometric convergence of the orbits to it, in the case of positively homogeneous maps acting on the interior of a cone, or of additively homogeneous maps acting on an AM-space with unit. This is motivated in particular by the analysis of dynamic programming operators (Shapley operators) of zero-sum stochastic games.
hal-00783682 , version 1 (01-02-2013)
Marianne Akian, Stephane Gaubert, Roger Nussbaum. Uniqueness of the fixed point of nonexpansive semidifferentiable maps. Transactions of the American Mathematical Society, 2016, 368 (2), ⟨10.1090/S0002-9947-2015-06413-7⟩. ⟨hal-00783682⟩
207 Consultations
0 Téléchargements
