Two-scale expansion with drift approach to the Taylor dispersion for reactive transport through porous media - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Chemical Engineering Science Année : 2010
In this work we study reactive flows through porous media. We suppose dominant Peclet's number, dominant Damköhler's number and general linear reactions at the pore boundaries. Our goal is to obtain the dispersion tensor and the upscaled model. We introduce the multiple scale expansions with drift for the problem and use this technique to upscale the reactive flow equations. Our result is illustrated with numerical simulations for the dispersion tensor.
CES09AllBrizzMikPiatcorr8postsubmission.pdf (494.01 Ko) Télécharger le fichier
hal-00784057 , version 1 (05-02-2020)
  • HAL Id : hal-00784057 , version 1
Grégoire Allaire, Robert Brizzi, Andro Mikelic, Andrey Piatnitski. Two-scale expansion with drift approach to the Taylor dispersion for reactive transport through porous media. Chemical Engineering Science, 2010, 65, pp.2292-2300. ⟨hal-00784057⟩
456 Consultations
179 Téléchargements
