Stability of the stationary solutions of neural field equations with propagation delays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Neuroscience Année : 2011
In this paper, we consider neural field equations with space-dependent delays. Neural fields are continuous assemblies of mesoscopic models arising when modeling macroscopic parts of the brain. They are modeled by nonlinear integro-differential equations. We rigorously prove, for the first time to our knowledge, sufficient conditions for the stability of their stationary solutions. We use two methods 1) the computation of the eigenvalues of the linear operator defined by the linearized equations and 2) the formulation of the problem as a fixed point problem. The first method involves tools of functional analysis and yields a new estimate of the semigroup of the previous linear operator using the eigenvalues of its infinitesimal generator. It yields a sufficient condition for stability which is independent of the characteristics of the delays. The second method allows us to find new sufficient conditions for the stability of stationary solutions which depend upon the values of the delays. These conditions are very easy to evaluate numerically. We illustrate the conservativeness of the bounds with a comparison with numerical simulation.
2190-8567-1-1.pdf (502.55 Ko) Télécharger le fichier
2190-8567-1-1.xml (448.66 Ko) Télécharger le fichier
Format : Autre
hal-00784425 , version 1 (04-02-2013)
Romain Veltz, Olivier Faugeras. Stability of the stationary solutions of neural field equations with propagation delays. Journal of Mathematical Neuroscience, 2011, 1 (1), pp.1-28. ⟨10.1186/2190-8567-1-1⟩. ⟨hal-00784425⟩
399 Consultations
115 Téléchargements
