Explicit Robin-Neumann schemes for the coupling of incompressible fluids with thin-walled structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
We introduce a class of explicit coupling schemes for the numerical solution of fluid-structure interaction problems involving a viscous incompressible fluid and a general thin-walled structure (e.g., including damping and non-linear behavior). The fundamental ingredient in these methods is the (parameter free) explicit Robin interface condition for the fluid, which enables the fluid-solid splitting through appropriate extrapolations of the solid velocity and fluid stress on the interface. The resulting solution procedures are genuinely partitioned. Stability and error estimates are provided for all the variants (depending on the extrapolations), using energy arguments within a representative linear setting. In particular, we show that one of them yields added-mass free unconditional stability and optimal (firs-order) time accuracy. A comprehensive numerical study, involving different examples from the literature, supports the theory.
RR-8224.pdf (2.06 Mo) Télécharger le fichier
hal-00784903 , version 1 (04-02-2013)
hal-00784903 , version 2 (07-02-2013)
hal-00784903 , version 3 (18-09-2013)
  • HAL Id : hal-00784903 , version 1
Miguel Angel Fernández, Jimmy Mullaert, Marina Vidrascu. Explicit Robin-Neumann schemes for the coupling of incompressible fluids with thin-walled structures. [Research Report] RR-8224, 2013. ⟨hal-00784903v1⟩
Collections
INRIA-RRRT
541 Consultations
554 Téléchargements
