Iterative implementation of services for the automatic evaluation of matching tools (v2)
This deliverable reports on the current status of the service implementa- tion for the automatic evaluation of matching tools, and on the final sta- tus of those services. These services have been used in the third SEALS evaluation of matching systems, held in Spring 2012 in coordination with the OAEI 2011.5 campaign. We worked mainly on the tasks of modifying the WP12 BPEL work-flow to introduce new features introduced in the RES 1.2 version; testing the modified work-flows on a local installation and on the SEALS Platform; writing transformations of result data to be compliant with the new SEALS ontologies specifications; and finally, extending the SEALS client for ontology matching evaluation for better supporting the automation of WP12 evaluation campaigns and to ad- vance in the integration with SEALS repositories. We report the results obtained while accomplishing these tasks.
