Hypergraph Partitioning
Hypergraphs are generalization of graphs where each edge (hyperedge) can connect more than two vertices. In simple terms, the hypergraph partitioning problem can be defined as the task of dividing the vertices of hypergraph into two or more roughly equal sized parts such that a cost function on the hyperedges connecting vertices in different parts is minimized.
