New interface
Journal articles
Perfect Sampling of Markov Chains with Piecewise Homogeneous Events
Ana Bušić 1 Bruno Gaujal 2 Furcy Pin 1
1 TREC - Theory of networks and communications
DI-ENS - Département d'informatique - ENS Paris, Inria Paris-Rocquencourt
2 MESCAL - Middleware efficiently scalable
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
Abstract : Perfect sampling is a technique that uses coupling arguments to provide a sample from the stationary distribution of a Markov chain in a finite time without ever computing the distribution. This technique is very efficient if all the events in the system have monotonicity property. However, in the general (non-monotone) case, this technique needs to consider the whole state space, which limits its application only to chains with a state space of small cardinality. Here, we propose a new approach for the general case that only needs to consider two trajectories. Instead of the original chain, we use two bounding processes (envelopes) and we show that, whenever they meet, one obtains a sample under the stationary distribution of the original chain. We show that this new approach is particularly effective when the state space can be partitioned into pieces where envelopes can be easily computed. We further show that most Markovian queueing networks have this property and we propose efficient algorithms for some of them.
Complete list of metadata
https://hal.inria.fr/hal-00787997
Contributor : Arnaud Legrand Connect in order to contact the contributor
Submitted on : Wednesday, February 13, 2013 - 2:57:20 PM
Last modification on : Tuesday, August 2, 2022 - 4:24:41 AM
Links full text
Identifiers
Citation
Ana Bušić, Bruno Gaujal, Furcy Pin. Perfect Sampling of Markov Chains with Piecewise Homogeneous Events. Performance Evaluation, 2012, 69 (6), pp.247-266. ⟨10.1016/j.peva.2012.01.003⟩. ⟨hal-00787997⟩
Share
Metrics
Record views
314
