Automatic Acquisition of Context Models and its Application to Video Surveillance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper addresses the problem of automatically acquiring context models from data. Context and human behavior are represented using a state model, called situation model. This model consists of different layers referring to entities, filters, roles, relations, situation and situation relationship. We propose a framework for the automatic acquisition of these different layers. In particular, this paper proposes a novel generic situation acquisition algorithm. The algorithm is also successfully applied to a video surveillance task and is evaluated by the public CAVIAR video database. The results are encouraging
Fichier non déposé
hal-00788082 , version 1 (13-02-2013)
Oliver Brdiczka, Pong Chi Yuen, Sofia Zaidenberg, Patrick Reignier, James L. Crowley. Automatic Acquisition of Context Models and its Application to Video Surveillance. 18th International Conference on Pattern Recognition, ICPR 2006., Yuan Yan Tang and Patrick Wang and G. Lorette and Daniel So Yeung, Aug 2006, Hong Kong, Hong Kong SAR China. pp.1175-1178, ⟨10.1109/ICPR.2006.292⟩. ⟨hal-00788082⟩
144 Consultations
0 Téléchargements
