Intrinsically Motivated Learning of Real World Sensorimotor Skills with Developmental Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
Open-ended exploration and learning in the real world is a major challenge of developmental robotics. Three properties of real-world sensorimotor spaces provide important conceptual and technical chal- lenges: unlearnability, high-dimensionality and unboundedness. In this chapter, we argue that exploration in such spaces needs to be constrained and guided by several combined developmental mechanisms. While in- trinsic motivation, i.e. curiosity-driven learning, is a key mechanism to address this challenge, it has to be complemented and integrated with other developmental constraints, in particular: sensorimotor primitives and embodiment, task space representations, maturational processes (i.e. adaptive changes of the embodied sensorimotor apparatus), and social guidance. We illustrate and discuss the potential of such an integration of developmental mechanisms in several robot learning experiments.
OudeyerBaranesKaplan13.pdf (1.97 Mo) Télécharger le fichier
hal-00788611 , version 1 (14-02-2013)
  • HAL Id : hal-00788611 , version 1
Pierre-Yves Oudeyer, Adrien Baranes, Frédéric Kaplan. Intrinsically Motivated Learning of Real World Sensorimotor Skills with Developmental Constraints. Baldassarre, Gianluca and Mirolli, Marco. Intrinsically Motivated Learning in Natural and Artificial Systems, Springer, 2013. ⟨hal-00788611⟩
Collections
ENSTA INRIA INRIA2
217 Consultations
716 Téléchargements
