A Body-centric Design Space for Multi-surface Interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce BodyScape, a body-centric design space that allows us to describe, classify and systematically compare multi-surface interaction techniques, both individually and in combination. BodyScape reflects the relationship between users and their environment, specifically how different body parts enhance or restrict movement within particular interaction techniques and can be used to analyze existing techniques or suggest new ones. We illustrate the use of BodyScape by comparing two free-hand techniques, on-body touch and mid-air pointing, first separately, then combined. We found that touching the torso is faster than touching the lower legs, since it affects the user's balance; and touching targets on the dominant arm is slower than targets on the torso because the user must compensate for the applied force.
BodyScape-Hal.pdf (2.47 Mo) Télécharger le fichier
Format : Figure, Image
hal-00789169 , version 1 (16-02-2013)
  • HAL Id : hal-00789169 , version 1
Julie Wagner, Mathieu Nancel, Sean Gustafson, Stéphane Huot, Wendy E. Mackay. A Body-centric Design Space for Multi-surface Interaction. CHI'13 - 31st International Conference on Human Factors in Computing Systems, ACM SIGCHI, Apr 2013, Paris, France. ⟨hal-00789169⟩
1499 Consultations
1616 Téléchargements
