Column Generation based Primal Heuristics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the past decade, significant progress has been achieved in developing generic primal heuristics that made their way into commercial mixed integer programming (MIP) solver. Extensions to the context of a column generation solution approach are not straightforward. The Dantzig-Wolfe decomposition principle can indeed be exploited in greedy, local search, rounding or truncated exact methods. The price coordination mechanism can bring a global view that may be lacking in some ''myopic'' approaches based on a compact formulation. However, the dynamic generation of variables requires specific adaptation of heuristic paradigms. The column generation literature reports many application specific studies where primal heuristics are a key to success. There remains to extract generic methods that could be seen as black-box primal heuristics for use across applications. In this paper we review generic classes of column generation based primal heuristics. We then focus on a so-called ''diving'' method in which we introduce diversification based on Limited Discrepancy Search. While being a general purpose approach, the implementation of our heuristic illustrates the technicalities specific to column generation. The method is numerically tested on variants of the cutting stock and vehicle routing problems.
hal-00790610 , version 1 (20-02-2013)
Cédric Joncour, Sophie Michel, Ruslan Sadykov, Dmitry Sverdlov, François Vanderbeck. Column Generation based Primal Heuristics. International Symposium on Combinatorial Optimization (ISCO), Mar 2010, HaMMamet, Tunisia. pp.695-702, ⟨10.1016/j.endm.2010.05.088⟩. ⟨hal-00790610⟩
312 Consultations
0 Téléchargements
