Services for the automatic evaluation of matching tools - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Contrat/Projet) Année : 2010
In this deliverable we describe a SEALS evaluation service for ontology matching that is based on the use of a web service interface to be implemented by the tool vendor. Following this approach we can offer an evaluation service before many components of the SEALS platform have been finished. We describe both the system architecture of the evaluation service from a general point of view as well as the specific components and their relation to the modules of the SEALS platform.
seals-122.pdf (2.56 Mo) Télécharger le fichier
hal-00793281 , version 1 (22-02-2013)
  • HAL Id : hal-00793281 , version 1
Christian Meilicke, Cassia Trojahn dos Santos, Jérôme Euzenat. Services for the automatic evaluation of matching tools. [Contract] 2010, pp.35. ⟨hal-00793281⟩
159 Consultations
213 Téléchargements
