Stochastic geometry for image analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 2011
Xavier Descombes
This book develops the stochastic geometry framework for image analysis purpose. Two main frameworks are described: marked point process and random closed sets models. We derive the main issues for defining an appropriate model. The algorithms for sampling and optimizing the models as well as for estimating parameters are reviewed. Numerous applications, covering remote sensing images, biological and medical imaging, are detailed. This book provides all the necessary tools for developing an image analysis application based on modern stochastic modeling
Fichier non déposé
hal-00793677 , version 1 (22-02-2013)
  • HAL Id : hal-00793677 , version 1
Xavier Descombes (Dir.). Stochastic geometry for image analysis. Xavier Descombes. Wiley-ISTE, pp.384, 2011, 978-1-84821-240-4. ⟨hal-00793677⟩
322 Consultations
0 Téléchargements
