An Adaptive Incremental Clustering Method Based on the Growing Neural Gas Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Usually, incremental algorithms for data streams clustering not only suffer from sensitive initialization parameters, but also incorrectly represent large classes by many cluster representatives, which leads to decrease the computational efficiency over time. We propose in this paper an incremental clustering algorithm based on "growing neural gas" (GNG), which addresses this issue by using a parameter-free adaptive threshold to produce representatives and a distance-based probabilistic criterion to eventually condense them. Experiments show that the proposed algorithm is competitive with existing algorithms of the same family, while maintaining fewer representatives and being independent of sensitive parameters.
AING.pdf (564.82 Ko) Télécharger le fichier
hal-00794354 , version 1 (25-02-2013)
Mohamed-Rafik Bouguelia, Yolande Belaïd, Abdel Belaïd. An Adaptive Incremental Clustering Method Based on the Growing Neural Gas Algorithm. 2nd International Conference on Pattern Recognition Applications and Methods - ICPRAM 2013, Feb 2013, Barcelona, Spain. pp.42-49, ⟨10.5220/0004256600420049⟩. ⟨hal-00794354⟩
382 Consultations
1501 Téléchargements
