Semantic multimedia document adaptation with functional annotations
The diversity of presentation contexts (such as mobile phones, PDAs) for multimedia documents requires the adaptation of document specifications. In an earlier work, we have proposed a semantic adaptation framework for multimedia documents. This framework captures the semantics of the document composition and transforms the relations between multimedia objects according to adaptation constraints. In this paper, we show that capturing only the document composition for adaptation is unsatisfactory because it leads to a limited form of adapted solutions. Hence, we propose to guide adaptation with functional annotations, i.e., annotations related to multimedia objects which express a function in the document. In order to validate this framework, we propose to use RDF descriptions from SMIL documents and adapt such documents with our interactive adaptation prototype.
