The second 'CHiME' Speech Separation and Recognition Challenge: Datasets, tasks and baselines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Distant-microphone automatic speech recognition (ASR) remains a challenging goal in everyday environments involving multiple background sources and reverberation. This paper is intended to be a reference on the 2nd 'CHiME' Challenge, an initiative designed to analyze and evaluate the performance of ASR systems in a real-world domestic environment. Two separate tracks have been proposed: a small-vocabulary task with small speaker movements and a medium-vocabulary task without speaker movements. We discuss the rationale for the challenge and provide a detailed description of the datasets, tasks and baseline performance results for each track.
vincent_ICASSP13.pdf (85.54 Ko) Télécharger le fichier
hal-00796625 , version 1 (04-03-2013)
  • HAL Id : hal-00796625 , version 1
Emmanuel Vincent, Jon Barker, Shinji Watanabe, Jonathan Le Roux, Francesco Nesta, et al.. The second 'CHiME' Speech Separation and Recognition Challenge: Datasets, tasks and baselines. ICASSP - 38th International Conference on Acoustics, Speech, and Signal Processing - 2013, May 2013, Vancouver, Canada. pp.126-130. ⟨hal-00796625⟩
581 Consultations
845 Téléchargements
