Distributed and boundary model predictive control for the heat equation
Abstract : We consider a model predictive control (MPC) scheme without stabilizing terminal constraints applied to the linear heat equation. We apply a method to analyze minimal stabilizing optimization horizons based on an exponential controllability condition. While the method is known to yield conservative quantitative results for concrete examples, our analysis shows that it precisely determines qualitative changes in the horizon for changing parameters and changing problem structures. Particularly, it is able to explain numerically observed differences in the stability behavior of MPC for distributed and for boundary control.
Type de document :
Article dans une revue
GAMM-Mitteilungen, WILEY-VCH Verlag GmbH, 2012, 35 (2), pp.131-145. <10.1002/gamm.201210010>
Liste complète des métadonnées
https://hal.inria.fr/hal-00800080
Contributeur : Estelle Bouzat <>
Soumis le : mercredi 13 mars 2013 - 10:43:09
Dernière modification le : lundi 21 mars 2016 - 11:30:04
Collections
Citation
Nils Altmüller, Lars Grüne. Distributed and boundary model predictive control for the heat equation. GAMM-Mitteilungen, WILEY-VCH Verlag GmbH, 2012, 35 (2), pp.131-145. <10.1002/gamm.201210010>. <hal-00800080>
Métriques
Consultations de la notice
111
