A Hybrid Metaheuristic for Multiobjective Unconstrained Binary Quadratic Programming
The conventional Unconstrained Binary Quadratic Programming (UBQP) problem is known to be a unified modeling and solution framework for many combinatorial optimization problems. This paper extends the single-objective UBQP to the multiobjective case (mUBQP) where multiple objectives are to be optimized simultaneously. For the purpose of approximating the Pareto set, we propose a hybrid metaheuristic which combines an elitist evolutionary multiobjective optimization algorithm and a state-of-the-art single-objective tabu search procedure by using an achievement scalarizing function. Finally, we define a formal model to generate diverse mUBQP instances and show the interest of the proposed approach in obtaining competitive results on large-size mUBQP instances with two and three objectives.
